LabVIEW APIs Discussions
Relinking the missing SubVIs
Hi all,
          I have a Toplevel VI (let's Call it as Main.VI) and it calls 4 subVIs (Let's Call them as Sub A.Vi, Sub B.vi, Sub C.vi, Sub D.vi). Now the files in the Hard disk are changed with a fixed Suffix (Let's say YYYY is added to all VIs). So my new VIs will be Main YYYY.vi. and the SubVis will be Sub A YYYY.vi, Sub B YYYY.vi, Sub C YYYY.vi and Sub D YYYY.vi) . Now when I open the Toplevel Vi it looks for the old subVIs.
Since I know the new Sub Vi's Names. Is there a Way to programattically replace those Sub VIs and save the top level VI? any one tried this using scripting before? please let me know before I reinvent the wheel.
Anish T.
அன்புடன்
தமிழ் நேரம்
முதல் இந்திய ஆய்வுமெகபொப சிற்பி
சோதனைநிறுத்தம் சிற்பி
மற்ற சான்றிதழ்கள்
யாதும் ஊரே! யாவரும் கேளிர்!!
Message 1 of 10
(17,224 Views)
How about doing it other way round?
If all your VIs are in the same project you can create a VI - let's call it "renamer.vi" - that open a reference to the project, then open references to the vis - as project items - (A, B, C, D) use the "save instrument and callers debug" method with the new names (A YYYY.vi, etc...)
See here :
Be carefull you have to start from the bottom of the VI hierachy
hope this helps
Epictetus
Antoine Chalons
Message 2 of 10
(14,031 Views)
This will work if the Vis are not renamed first. but unfortunatly the VIs are renamed in the hard disk first. Is there a work around for this situation. I would like to avoid manually opening each VI and replacing all the question marks with the new names. I would like to automate the process.
அன்புடன்
தமிழ் நேரம்
மற்ற சான்றிதழ்கள்
Message 3 of 10
(14,031 Views)
I know this isn't scripted, but can't you replace a project item with another?  In LV 2009, the "find all instances" also incorporates a replace function.
If you open all the top-level VIs, then all the subVIs will be in memory, so you only have to replace each subVI once.
How to do this in scripting, I do not know of an easy way.  You may have to make a "replace" function yourself.
Marshal Horn
Message 4 of 10
(14,031 Views)
I'm not using LV 2009 for customer project so I don't know all the new features, but at least in 8.6 you can't use the "find all instances" on a "question mark VI". Is is possible in LV 2009?
If not that would make a cool feature idea!
Epictetus
Antoine Chalons
Message 5 of 10
(14,031 Views)
If you're ready to spend time developping a script for that matter I assume it means you have a lot of sub-vis to rename, right?
Maybe you can make VI (not script) to just rename again all your sub-vis on disk to the original name they had (like if you were doing it manually from the windows explorer) and the use the method I suggested above to script the addition of YYYY in the name of sub-vis.
Epictetus
Antoine Chalons
Message 6 of 10
(14,031 Views)
I agree. Renaming in LabVIEW is much easier than relinking to renamed VIs.
Chris Bolin
LabVIEW Partner Program, CLA
Message 7 of 10
(14,031 Views)
My mistake.  You cannot use the "find all instances" on a missing VI, or the "find and replace" from the VI itself.  However, you can use the "Replace with" from the project explorer.
http://content.screencast.com/users/kamocat/folders/Jing/media/87b3befe-906d-4a48-a869-5a4f401024d3/00000061.png
This still isn't automating the whole process, but it would make it less painful.
Marshal Horn
Message 8 of 10
(14,031 Views)
Hi ,
Can someone explain how to start from bottom of hierarchy programatically.?
Or does anyone have a readymade vi to do the renaming process without affecting linking of controls and subvis
Waiting For the inner calling 🙂
Message 9 of 10
(13,464 Views)
where i can find rename vi
Message 10 of 10
(7,847 Views)
