LabVIEW APIs Discussions
Import - Export Shared Variable Configuration Programmatically
It is available as a popup menu on a Library but does anyone know if there is a method available to programmatically Import and Export a Shared Variable configuration (.csv) file?
If not, is there any chance of someone posting a wrapper for it?
Whilst I am sure the core VI's are there in the DSC to do it, it really is a complicated set of methods that covers a wide range of data-types, cases, properties etc... making it extremely time consuming to cover everything.
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
(6,131 Views)
I'm having the exact problem at this time. I know this post is 5 years old but has anyone found a solution to this?
Sandro
(4,690 Views)
