LabVIEW APIs Discussions
Creating an array constant with n-elements - best practice (by VIScript ;))
Hi guys,
i have struggled around with this topic for half of a day... finally i found a solution that works out for me, but i guess there is a better solution.
My goal what i actually want to do was just to create an string array constant with n-elements of data i want to define.
My first approach was to create a string array constant on the block diagram by scripting - no problem here. But i failed in edtiting the array, or in other words: i couldnt fill the array with values, or at least initialized an value of the array. (Errors like "This function is not implemented yet" or Labview crashes where the reasons)
So i ended up in the solution below (attached image):
I create two string array constants - one "working copy", one target. Then i convert the working copy into a frontpanel element an fill it with my pre defined values. Afterwards i copy the data from the working copy to the target, and in the end, the vi deletes the working copy.
My question: Is there a simpler way, or has anyone made experiences made about editing/creating array constants on the blockdiagram?
Looking to hear from you.
Cheers Chris
(5,305 Views)
