LabVIEW APIs Discussions
Dropping an existing typedef
Dropping an existing typedef on a front panel is causing me some issues.  Currently, I'm
trying things similar to:
This comes up with various type mismatch errors, depending on the owning reference (VI or front panel).  Changing the SubVI class to GenericSubvi or similar classes doesn't seem to make a difference.
Anyone have any hints?
Joe Z.
(4,369 Views)
While a typedef is technically a VI, when you drop it on a front panel, it's simply a control.
I can't check at the moment, but I assume that changing the class to Control (or even Generic or GObject, as it only affects the type of the output reference) should work.
___________________
Try to take over the world!
(3,251 Views)
Changing the type to Control worked beautifully, thanks!
Joe Z.
(3,251 Views)
