LabVIEW APIs Discussions
Disable Diagram : Programatically select enabled frame
Does anyone know of a way to set which frame of a disabled diagram structure is the enabled frame using scripting?
Message 1 of 17
(8,826 Views)
I have not tried it, but there is an ActiveFrame property which should do the job.
Note that the diagram disable structure normally switches on environment variables.  Approach with caution.
Message 2 of 17
(5,372 Views)
Thank you! That works. I tried this before posting the questing and it didn't seem to work but it does...DOH!
Message 3 of 17
(5,372 Views)
You can simplly use Case structure..!!
Greeting from India,
Malhar
Message 4 of 17
(5,372 Views)
I'd like to use nested disable diagram structures instead of a case structure such that certain code doesn't compile. I've run into a new problem and I'll ask here while I'm searching, but does anyone know a way to get a reference to a disable diagram structure within a disable diagram structure? The BD.Nodes property doesn't recursively return nodes within nodes.
Message 5 of 17
(5,372 Views)
You have two options.
  1. Get the reference the normal way, but wire the owner refnum with the frame or diagram refnum of the frame in the top level conditional disable the lower level conditional disable is in.
  2. Use Traverse to return all the conditional disable references, then select the one you need.  Custom labels are your friend here.
Message 6 of 17
(5,372 Views)
Thanks DFGray, but I did it a different way. I cast the disable diagram reference to a structure reference and then used the Diagrams[] property and then searched the Nodes[] property of that for a disable diagram structure.
Message 7 of 17
(5,372 Views)
Couldn't you simply use Conditional Disable Structure and define disable symbols within the project? That is exactly what it is for...
Message 8 of 17
(5,372 Views)
Conditional disable only operates on a logical combination of platform / processor bitness (32 vs 64) / envorinment (dev/executable/etc.). If i want certain code to not compile based on other conditions I can use nested disable diagram structures or the call by reference node.
Message 9 of 17
(5,372 Views)
No, you can create any symbol (variable) and assign it any integer value. Yo can do it with Project->Properties->Conditional Disable Symbols. Then for each frame of Conditional Disable Structure you can define an expression using these symbols.
Message 10 of 17
(5,372 Views)
