LabVIEW 2021 Public Beta
[New Feature] "Run When Opened" Security Warning
LabVIEW will warn the user when opening VIs that have “Run when opened” behavior:
The intention is to protect users from malicious code disguised as examples. Note that LabVIEW will not prompt for VIs in “trusted” locations such as the LabVIEW folder.
Known Issue
  • The ability to configure this security warning using Tools»Options»Security is not in this Beta, but in the released version you will be able to disable the prompt universally or for specific VIs.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 1 of 11
(6,314 Views)
great that NI recognizes this problem and implements countermeasures 🙂
- will it also be possible to add new folders to the trusted locations?
- will it be possible to completely turn off this feature (LabVIEW.ini tokens ?)
Background: my CI build tool-chain runs a vi from console (not using LabVIEW-CLI yet since my build tools predate these recent developments)
Or I finally might have to rework my CI build tools ...
Thanks, Benjamin
_________________________
CLA
Message 2 of 11
(6,100 Views)
There is an INI token that disables the dialog completely, and this will be accessible via Tools»Options in the release (but this setting isn't in this Beta).
We aren't currently planning to add trusted folders; however, you can add specific trusted VIs.
Christina Rogers
Message 3 of 11
(6,075 Views)
Hi Is this option of editing the INI file released yet?
Message 4 of 11
(5,235 Views)
It seems so.
I can find it in the Options as described.
The token is called "RunWhenOpened.Behavior"
CLA
Message 5 of 11
(5,233 Views)
Is there any way to edit the ini file for this purpose?
Message 6 of 11
(5,222 Views)
Could you please share how to find this option?
Message 7 of 11
(5,218 Views)
The Tools»Options dialog has a Security category with options that affect "Run When Opened" VIs.
Christina Rogers
Message 8 of 11
(5,163 Views)
Let me confirm the token setting of INI file. Is this correct?
RunWhenOpened.Behavior=<Number>
0: Display warning dialog
1: Open VI, but do not run
2: Run VI without warning
Junichi
Message 9 of 11
(5,112 Views)
Yes, those INI token values are correct.
Christina Rogers
Message 10 of 11
(5,033 Views)
