LabVIEW 2021 Public Beta
[Bug] VIM Same inputs different outputs
(2,064 Views)
If I run your "VIM Same inputs different outputs.vi" on my LV21.b11 on an ARM MBPro the output looks as shown in the attached picture. Not quite sure where the source of the problem could be though.
(2,018 Views)
Filed as Bug 1459744.
Confirmed to exist in LV2020 and LV2021. Bug does not appear to be VIM specific since it persists if you convert the instance VIs to real VIs. No idea what's going on.
(1,972 Views)
R&D investigation found that the unbundle nodes in the two loops aren't the same, and the VI behavior is correct. We recommend using "Show full names" to avoid potential confusion like this.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(1,918 Views)
