JDP Science Tools
Programmatically serializing to JSON and back to Flattened String
I'm trying to programmatically serialize typedef'd clusters to and from JSON using JSONText. It serializes fine, but on the way back in I can't manage to reconstitute it as a flattened string.  I think the problem is that I can only retrieve the prototype cluster (for type and defaults) as a variant.
In my example, I want the bools 1,2, and 3 to be true, but 3 resists all my efforts.
Am I misusing the library? Is it not possible?
(2,660 Views)
I solved my problem by piping the variant output of From JSON Text.vim into and out of the defining control. If anyone knows an easier way, please let me know.
(2,623 Views)
It isn't clear to me what you trying to do.  Why are you interested in these booleans?  Setting your cluster is trivially easy, as you show.  What more are you needing?
(2,607 Views)
