JDP Science Tools
From JSON Text.vim not working on Linux
I'm using the To JSON Text.vim to save the cluster which contains LabVIEW classes. Then save it to file, load, and convert it back with From JSON Text.vim to my cluster. This operation works perfectly on Windows LabVIEW 2020. However, it doesn't work on Linux (Ubuntu LabVIEW 2020).
I created POC vi to easily test the issue:
When you lunch it on Ubuntu, the following error will appear:
Code: 1403
SubVI in JSONtext.lvlib:JSON text to Variant.vi:4410001->JSONtext.lvlib:JSON text to Variant.vi:4410002->load from JSON.vi
Have you any clue what's the reason for this error?
The test project can be found in the attachment.
Message 1 of 10
(6,491 Views)
What JSON is produced?   On Windows it is:
"Square.lvclass":"§§AAAAARAOU3F1YXJlLmx2Y2xhc3MAAAAAAAAAAAAAAAA", "Triangle.lvclass":"§§AAAAARIQVHJpYW5nbGUubHZjbGFzcwAAAAAAAAAAAAA"
Message 2 of 10
(6,473 Views)
For Ubuntu it is:
{"Square.lvclass":"§§AAAAARAOU3F1YXJlLmx2Y2xhc3MAAAAAAAAAAAAAAAA","Triangle.lvclass":"§§AAAAARIQVHJpYW5nbGUubHZjbGFzcwAAAAAAAAAAAAA"}
so there is a difference.
Message 3 of 10
(6,436 Views)
I have a suspicion of the reason. Unfortunately don't have Linux to test, but I can rework things to prevent this bug (if it is what I think it is).
Message 4 of 10
(6,412 Views)
This is the only modified subVI that I needed to modify.  If you could try substituting in (it's at vi.lib\JDP Science\JSONtext\support\JSON to LVObject.vi) and let me know if it works.
Message 6 of 10
(6,406 Views)
Thank you for your answer. Unfortunately after replacing "JSON to LVObject.vi" the error still pops up. I have tried to dig into code to find the source and exactly in that VI which you send under UTF8 case, "Unflatten From String.vi" throws error 1403. Following snipped shows what is an input for that vi.
Message 7 of 10
(6,388 Views)
 Sorry that didn't work.  Can you try this new version?
Message 8 of 10
(6,330 Views)
It's working now. Thank you for fixing the bug.
Message 9 of 10
(6,311 Views)
A 1.6.9 version of JSONtext (including this fix) has been submitted to the Tools Network
Message 10 of 10
(6,268 Views)
