JDP Science Tools
JSONtext Path with dot in name
I'm using JSONtext to retrieve data from a JSON file (JSON from another source).
The JSON items have dots in their name, for example:
  "Header": {
    "ecat.cmd": [
      "04",
      16,
      4
When using $. path notation, the dots represents breaks between names, but above you can see an entity with a dot in the name itself, so this doesn't work:
Google suggests that you can escape the dot in the JSON path: $.Header.ecat\.cmd
Also, it suggests you can encapsulate: %.Header.\"ecat.cmd\"
Neither works. Is there an expected nomenclature for this in JSONtext?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(7,084 Views)
Accepted by Thoric
Try this:
$.Header."ecat.cmd"
(7,058 Views)
This is how it is described in the extended help (though perhaps this is not clear enough):
Object items can also be specified as their proper JSON string.   This allows the use of characters in names that would otherwise not parse correctly.  For example:
$."My Name that contains \"quotes\", []brackets, and dots."
Note that this must be proper JSON (thus the escaped quotes in the example).
Note that JSONpath doesn't have an actual specification, so I have not held to anyone else's ideas too closely.  Rather than make up a whole set of escaping rules specific to JSONpath, I instead defined the path as using JSON Strings, with unquoted LabVIEW strings as an option, just for convenience.   The real path is $."Header"."ecat.cmd".
(7,052 Views)
Thanks. Now that you've explained it I can see what the help means, but I think I would never have realised otherwise. It could use some rework, maybe breaking the example into three and showing that quotes around the names are equally valid (and arguably better).
(7,044 Views)
