JDP Science Tools
JSONtext: JSON Schema?
James,
I didn't find out "Generate JSON Schema from LV Datatype" at JSONtext library as below. Can you please share where we are able to download it?
Message 21 of 31
(3,004 Views)
I think there is no generate Schema from Labview date type functionality yet in JSONtext.
I'm currently working on one and will try  release a package soon.
Message 22 of 31
(2,999 Views)
I've needed this too and have made some progress. Would be happy to share/collaborate.
Message 23 of 31
(2,943 Views)
I've created a working repo here: https://github.com/JKISoftware/generate-json-schema-labview
Note that the code is quite simple (not much more complicated than what you're looking at below)
Message 24 of 31
(2,938 Views)
Hi Jim,
Is the repo public?
I can't find it on GitHub..
Cheers
Epictetus
Antoine Chalons
Message 25 of 31
(2,925 Views)
Hi Jim,
I have made some more progress and could make the repo now public: novatron-fusion/LabVIEW-JSON-Schema-Generator (github.com)
Please have a look! I would be glad for any feedback.
Message 26 of 31
(2,888 Views)
I've also now added a simple Schema Generator to the package:
Message 27 of 31
(2,678 Views)
Hi guys,
I am not very savvy with JSON formats, and I would like to use the 'Validate Against JSON Schema.vi' to show user where a mistake is:
How would I infer the JSON Schema from an already existing JSON file?
I am confused as to how to format the JSON Schema input of the above VI.
Would anyone be able to help me out, please?
Below is an example JSON file content:
Spoiler
   "Recipe":{
      "UART_Ports":[
            "Device_Name":"UART1",
            "Comm_Name":"UART1",
            "Serial Settings":{
               "timeout(ms)":1000,
               "baud rate":19200,
               "data bits":8,
               "parity":0,
               "stop bits(10;15;20)":10,
               "flow control":0
            "Device_Name":"UART2",
            "Comm_Name":"UART2",
            "Serial Settings":{
               "timeout(ms)":1000,
               "baud rate":19200,
               "data bits":8,
               "parity":0,
               "flow control":0
      "DAQ_config":{
         "Digital_Inputs":[
               "Alias":"Bon_Down",
               "Channel_Address":"cDAQ1Mod1_NI9375/port0/line11"
               "Alias":"Air_Pressure_OK",
               "Channel_Address":"cDAQ1Mod1_NI9375/port0/line14"
         "Digital_Outputs":[
               "Alias":"Close_Canopy",
               "Channel_Address":"cDAQ1Mod1_NI9375/port1/line0"
               "Alias":"BON_Up",
               "Channel_Address":"cDAQ1Mod1_NI9375/port1/line3"
         "Analog_Inputs":[
         "Analog_Outputs":[
      "Test steps":[
            "retests":0,
            "continue on failure":false,
            "Log results":true,
            "Test_name":"step1",
            "Enable":true
            "retests":0,
            "Log results":true,
            "Test_name":"step2",
            "Enable":true
      "UUT_Spec_Limits":[
      "General Info":{
         "Model Name":"modelName",
         "Event Logger":false
      "DataBase_Config":{
         "Enable DB":true,
         "Results Table Name":"tbl_name"
      "Execution_Config":{
         "Stop On First Fail":true,
         "Nr of Repeat":0,
         "Repeat Sequence":false,
         "Sleep before repeat":0
      "Process_Conditions":{
         "Start_Conditions":[
               "Channel Alias":"Air_Pressure_OK",
               "Expected State":true
               "Channel Alias":"E_Stop_OK",
         "Test_Running_Conditions":[
         "Stop_Conditions":[
         "Abort_Conditions":[
               "Channel Alias":"STOP_Signal",
               "Expected State":false
   "Project_Specific":{
      "Product Config":{
         "Product SKU":"",
         "...Technician Entry...":""
      "Station Config":{
         "Station Option (eg. DB)":"",
         "Station Option (eg. ID)":"",
         "...Engineer Entry...":"",
         "BarcodeLength":23,
         "BarcodeDashNumberPresent":false,
         "UserIdMajorMinorBuild":"0.0.14"
      "Move_To_TFW_PC":{
         "TCP/IP Present":false,
         "Use_Limits_Database":true
      "CW Mask Limits":[
            0,
            -78
            460,
            -78
      "CM Mask Limits":[
            0,
            -77
            460,
            -77
Message 28 of 31
(1,575 Views)
There is a generate schema function in the library that should make a basic schema from your JSON.
Message 29 of 31
(1,564 Views)
Thanks, wasn't aware of that function, I'll give it a go.
Message 30 of 31
(1,556 Views)
