取消
显示结果
搜索替代
您的意思是:
wt2030 GPIB Can't read from WT 2030
We downloaded the driver from NI website for WT2030 Yokogawa, while trying to run the VI errors keep showing up as ERROR: 1073807194 Cannot write. We use the software provided by Yokogawa the meter seems fine communicating to the computer.  We have no idea why this is happening, can anyone help?
0 项奖励
1 条消息(共 13 条)
4,754 次查看
Yes, I can and will help you. But you have wait till begin of the next week.
Kees
0 项奖励
2 条消息(共 13 条)
4,741 次查看
Thank you, see you next week.
0 项奖励
3 条消息(共 13 条)
4,738 次查看
What kind of interface do you use ?
Do you use your own VI or one of the examples from the drive package ?
Kees
0 项奖励
4 条消息(共 13 条)
4,734 次查看
We use one of the example from the driver package.
0 项奖励
5 条消息(共 13 条)
4,719 次查看
What is the interface you use ?  GPIB or ??
0 项奖励
6 条消息(共 13 条)
4,717 次查看
GPIB to USB
0 项奖励
7 条消息(共 13 条)
4,714 次查看
Did you try to find for instruments in MAX?
greetings from the Netherlands
0 项奖励
8 条消息(共 13 条)
4,707 次查看
We try to use Measurement and automation Explorer (MAX) to send the query, and getting nothing in return. We think we didn't setup MAX right.
The example in the package seems to be working in idenifying the meter model, but got error once it trying to query the STAT:VAL? command.
Some background on us and our knowledge level on labview.
We are two 4th year electrical engineering students working on our capstone project.  We had 3 labs working on labview, but we never learn how to actually setup labview to communicate with hardware, since it is all done for us.
0 项奖励
9 条消息(共 13 条)
4,703 次查看
in MAX there is a tab find instruments when selected the gpib interface.
just test
0 项奖励
10 条消息(共 13 条)
4,696 次查看
