08-29-2013 06:47 AM
The GPIB standard uses an addressing and handshaking scheme to transfer data. Only 1 instrument can be addressed at a time since there is only 1 set of data lines. In another post, you said this is a really old instrument. I would say that the instrument is what is determining your transfer rate.
08-29-2013 07:39 AM
Thanks. So does it imply that using two GPIB cards and two data line is better and it could address device in parallel if I use two data line two cards, right?
08-29-2013 08:37 AM
I have never tried having a second GPIB card in my computer. I would think it should work. Yes, two interfaces can run in parallel.
