will data transfer in parallel in GPIB interface?
The GPIB standard uses an addressing and handshaking scheme to transfer data.  Only 1 instrument can be addressed at a time since there is only 1 set of data lines.  In another post, you said this is a really old instrument.  I would say that the instrument is what is determining your transfer rate.
Message 11 of 13
(1,270 Views)
Thanks. So does it imply that using two GPIB cards and two data line is better and it could address device in parallel if I use two data line two cards, right?
Message 12 of 13
(1,264 Views)
Accepted by dragondriver
I have never tried having a second GPIB card in my computer.  I would think it should work.  Yes, two interfaces can run in parallel.
Message 13 of 13
(1,254 Views)
