Ah.  Yes the DB-9 table in the KB document is horribly incorrect (it appears to be a copy of the 10-position table that was never edited).  The table in the user manual is correct.  Also, check out the quick reference card at:
http://digital.ni.com/manuals.nsf/websearch/7A8939051A4C0DEB86256E9800596033?opendocument&Submitted&&node=132090_US
Can you supply the KB number where you found the bad table so I can get a correction made?
