visa read no output show up from read buffer
Is there a mistake in my program? my read buffer did not show up. i attached my VI file for reference. I dont know what to do anymore. i use arduino uno with HC-SR04. Thank you!!!
(3,146 Views)
Accepted by topic author AMIR2810
How much data is your Arduino sending? At least 100 Chars within 10 seconds default time out I hope.
And did you specify an end character the default is LF (ASCII 10 decimal).
So if you used println it should work anyhow.
Or you have swapped the send and receive line of the rs232 connection?
greetings from the Netherlands
(3,122 Views)
Im sorry, im newbie in labview.
i did not specify an end character.
how do i swap the send and receive line of the rs232 connection?
Herewith i attached my arduino code hopefully can help in any way.
(3,119 Views)
thank you!!!!
its done after i check everything u ask me..
thanks for your help!!!
(3,115 Views)
thanks for reporting the succes
(3,109 Views)
