USB-6361
Does anyone know if USB-6361 DAQ has a software which allows to name, set-up ( adding gain, ... ) etc the various analog & digital signals from a PC ?
Best regards
(3,374 Views)
The driver is DAQmx, and it should come with NI-MAX (Measurement and Automation eXplorer).  MAX is currently the software you will need to configure your DAQ and do some basic things.  Beyond the simple setup and test, you will want a real programming environment, such as LabVIEW, to do whatever anlaysis, logging, etc you need done with the data.
(3,355 Views)
Hi there,
I just add some info after the good answer of crossrulz :
You can download the NI-DAQmx driver here. To choose the version to download :
    * USB-636x devices are supported by NI-DAQmx 9.5 and later
    * Here is the compatibility table between NI-DAQmx and Microsoft Windows.
    * Here is the compatibility table between NI-DAQmx and LabVIEW.
If you don't have NI-MAX yet, don't worry, it is included with the NI-DAQmx driver.
Reagrds guys !
Bilsix.
(3,345 Views)
