visa com libraries
I'm having problems with the VISA-Com Libraries to communicate with a Keysight (N6700B) power supply.
I have some C# Code i am compiling in Visual Studio 2015, and it does not work. However, if i compile the same code in Visual Studio 2012, then it works.
Basically i am just doing simple communication with the device
using Ivi.Visa.Interop;
string address = "USB0::2391::2311::MY54002380::0::INSTR";
ResourceManager rm = new ResourceManager();
FormattedIO488 myDmm = (IMessage)rm.Open(address , AccessMode.NO_LOCK, 2000, "");
myDmm.WriteString("*RST"); // reset the device
myDmm.WriteString("*IDN?"); // request the IDN string;
string IDN = myDmm.ReadString(); // This is where it fails, returning: "VI_ERROR_TMO: A timeout occurred"
Also, the power supply has an error state of:
Error -420, Query UNTERMINATED
The code does not work with VS2015, but it DOES work with VS2012.
(In VS2012 i get no errors at all.)
I have tried downloading the latest drivers from KeySight, and it still does not work.
(www.keysight.com/find/iosuitedownload)
Does anyone have any idea why it would be breaking with VS2015 but work with VS2012?
I've looked up "Quere Unterminated" and some say that it could be a missing Termination character "\n", i've tried adding the "\n" to both writeStrings, and it still fails.
I've also tried:
myDmm.IO.TerminationCharacterEnabled = true; // before the write string
// and
myDmm.IO.TerminationCharacterEnabled = false; // before the write string
// and
myDmm.FlushWrite(true); // after the write string
// and
myDmm.FlushWrite(false); // after the write string
// and
myDmm.WriteString("*IDN?" + myDmm.IO.TerminationCharacter);
None of the above was necessary in VS2012, but i'm just trying different things with VS2015
(5,821 Views)
Are you saying that the drivers won't work on VS2015, because they only have listed: VS2008, VS2010, VS2012?
I would think VS2015 would still work, since i can compile with the .NET 4.5 that it says it supports.
(5,809 Views)
