viScanf not succeeding
Hi All,
I am trying to collect data from an oscilloscope using Visa programming. I have modified the existing program examples bufferio.cpp and formatio.cpp. When I use the viScanf function, it does not succeed and reports me error. I am attaching the modified code that I use.
double* ReadWaveform(ViSession vi, long* elements)
	ViStatus	status;
	float		yoffset, ymult;
	ViChar		buffer[256];
	ViChar		c;
	long		count, i;
	double*		ptr = NULL;
	unsigned char		szBuff[256] = { 0,};
	static ViUInt32 Wrcount;
	static char stringinput[512];
	assert(elements != NULL);
	status = viSetAttribute(vi,VI_ATTR_WR_BUF_OPER_MODE, VI_FLUSH_ON_ACCESS);
	status = viSetAttribute(vi,VI_ATTR_RD_BUF_OPER_MODE, VI_FLUSH_ON_ACCESS);
	 /* Set the timeout for message-based communication*/
   status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 25000);
   strcpy(stringinput,"MEASUREMENT:IMMED:SOURCE1 CH3");
   status = viWrite (vi, (ViBuf)stringinput, (ViUInt32)strlen(stringinput), &Wrcount);
   if (status < VI_SUCCESS)
      printf("Error writing to the device\n");
      goto error;
	// Turn headers off, this makes parsing easier
	status = viPrintf(vi, "header off\n");
      printf("Error writing Header off to the device\n");
      goto error;
	// Get record length value
	status = viQueryf(vi, "hor:reco?\n", "%ld", elements);
	printf("The number of elements is %ld \n",*elements);
      printf("Error getting the elements value\n");              WORKS FINE
      goto error;
	// Make sure start, stop values for curve query match the full record length
	status = viPrintf(vi, ":data:start 1;:data:stop %d\n", *elements);
      printf("Error writing start and stop values\n");
      goto error;
	// Get the yoffset to help calculate the vertical values.
	status = viQueryf(vi, "WFMOutpre:YOFF?\n", "%f", &yoffset);
	printf("The yoffset value is %f \n",yoffset);                WORKS FINE
      printf("Error getting the yoffset value\n");
      goto error;
	// Get the ymult to help calculate the vertical values.
	status = viQueryf(vi, "WFMOutpre:YMULT?\n", "%f", &ymult);	     WORKS FINE
	printf("The ymult value is %f \n",ymult);
      printf("Error getting the ymult value\n");
      goto error;
	// Request 8bit binary data on the curve query
	status = viPrintf(vi, "DATA:ENCDG RIBINARY;WIDTH 1\n");
      printf("Error writing the encoding width value to the device\n");
      goto error;
	// Request the curve
	status = viPrintf(vi, "CURVE?\n");
      printf("Error writing CURVE to the device\n");
      goto error;
    // Always flush if a viScanf follows a viPrintf or viBufWrite.
	status = viFlush(vi, VI_WRITE_BUF | VI_READ_BUF_DISCARD);
      printf("Error writing Flush to the device\n");
      goto error;
	// Get first char and validate
	status = viSetAttribute(vi,VI_ATTR_RD_BUF_OPER_MODE, VI_FLUSH_DISABLE);
	status = viScanf(vi, "%c", &c);					ERROR HERE
      printf("Error Setting attribute and getting a char \n");       PRINTING THIS MESSAGE
      goto error;
	assert(c == '#');
	// Get width of element field.
      printf("Error getting width of element from the device\n");
      goto error;
	assert(c >= '0' && c <= '9');
	// Read element characters
	count = c - '0';
	for (i = 0; i < count; i++)
		printf("Error reading element characters from the device\n");
		goto error;
	// Read waveform into allocated storage
	ptr = (double*) malloc(*elements*sizeof(double));
	for (i = 0; i < *elements; i++)
		goto error;
		ptr[i] = (((double) c) - yoffset) * ymult;
		fprintf(fp,"%c \t", ptr[i]);
      printf("Error Flush to the device\n");
	  goto error;
	return ptr;
error:
	// Report error and clean up
	viStatusDesc(vi, status, buffer);
	fprintf(stderr, "failure: %s\n", buffer);
	if (ptr != NULL) free(ptr);
	return NULL;
What should I do to get the data using viScanf. Can somebody please help? Thanks
Ashwin
(3,991 Views)
It works now. I was not looking at the correct specifier. Also I replaced the viWrite with viPrintf for setting the oscilloscope channel as I think we should not use viWrite and viPrintf in the same session (not sure though).
status = viPrintf(vi, "DATA:SOURCE CH3\n");
(3,985 Views)
