tnt 5002 interface
I set the above initialization to realise a tnt 5002 interface in one  chip  Turbo+7210 mode
I couldn't get it to generate interrupt. Is there anything missing in the above initialization?
i try to communicate whit the Dos ..........whit  findlstn   Adress or ibln primary adress(pad)  and sad
I alwas have Device at address 7 ist not responding
 WriteGpib(SfrRst,CMDR);        // Reset the Turbo 4882 on the TNT SftRst=0x22
 WriteGpib(0x80,SPMR);          // Place the TnT in Turbo+7210 Mode
 WriteGpib(0x80,AUXMR);
 WriteGpib(0x99,SPMR);
 WriteGpib(0x99,AUXMR);
 WriteGpib(E_ONEC,HSSEL);       // Configure the TNT for One Chip Mode
 WriteGpib(RstChip, AUXMR);     // Assert the local pon message
 WriteGpib(0x00, KEYREG);
                                // Set the Gpib Address
 WriteGpib(0x31, ADMR);
 WriteGpib(0x07, ADR0);
 WriteGpib(0xE0, ADR1);
WriteGpib(0x00,SPMR);            //Serial poll reponse
 WriteGpib(E_ADSC, IMR2);     // enable adresse change interrupt
 WriteGpib(E_DGB|E_DGA, HIER); // Select the deglitching circuit for the TNT 4882
 WriteGpib(HLDI, AUXMR);        // Prevent for data reception
 WriteGpib(PON, AUXMR);         // Clear the Local pon message
// if aderressed to listen  or adress
if(ReadGpib(ADSR) | LA)    // define LA 0x04
Message 1 of 151
(5,393 Views)
Let me clarify a couple things first.
Turbo+7210 mode is not implemented in the TNT5002, only One-chip mode and a 9914 mode are implemented. It is not necessary to set the ONEC bit in HSSEL as it is set by default. The beginning of your code is not necessay as it assumes non One-chip mode.
How do you determine if an interrupt has occurred? Do you just wait for your software ISR to execute? Have you tried reading ISR2 to see if the ADSC interrupt is asserted?
I see you are reading the ADSR and branching based on the LA bit. When you execute this code is the LA bit set?
Also, when you do a FindLst at the host does it find anything at address 7?
Message 2 of 151
(5,369 Views)
yes i have try to read the ISR2 Register but the result is ISR2=0  and the ADSR give me 0x40(ADSR value is 0x40 , 0x40 is ATN clear)  , and when i do a findLst at address 7 i didn't find any thing it still answer  device at adress 7 is no reponding....... is my Code correct?
I am sorry for my englisch  i am french, I leave in France
Thank You..........
Message 3 of 151
(5,364 Views)
Following the FindLstn can you read the following registers and report the values?
ISR0
ISR1
ISR2
ISR3
STS1
STS2
ADSR
Message 4 of 151
(5,355 Views)
Hello Mr Collin
Thank You..........
Can't i have your e-mail ?
Can' t'you help me in futur , i am student and for my praktika, i have to write a Gpib aplication whit the tnt 5002,  now i am try to gate a communication between the tnt 5002 and the gpib_pci ...
Thank you Mr Collin.............
Message 5 of 151
(5,357 Views)
Yes here are the value
ISR0=0x00
ISR1=0x01
ISR2=0x00
ISR3=0x00
STS1=0x8F
STS2=0x9A
ADSR=0x40
thank you..
Message 6 of 151
(5,353 Views)
i have make a mistake ISR1=0x00
Message 7 of 151
(5,349 Views)
Those all seem to be the default values for the registers. It is as if nothing is happening inside the TNT5002.
Please do the following test after your initialization routine:
Write 0x11 to CNT0
Write 0x22 to CNT1
Write 0x33 to CNT2
Write 0x44 to CNT3
Read CNT0
Read CNT1
Read CNT2
Read CNT3
Reply with the values you read from each register.
Message 8 of 151
(5,324 Views)
I do it and i read the new  value..
ReadGpib(CNT0)=0x11
ReadGpib(CNT1)=0x22
ReadGpib(CNT2)=0x33
ReadGpib(CNT3)=0x44
WriteGpib(0xFF, IMR3);  //  i write IMR3=0xFF
ReadGpiB(IMR3);            // I read 0xFF
WriteGpib(0x02, AUXMR);// Reset chip
ReadGpib(IMR3);    // i read 0x00
i thing my read and write work propertly,,,,
to drive the tnt 5002 in gen 4882 mode what i have to do? , i have assert the pin mode to gnd...
Message 9 of 151
(5,316 Views)
Can you double-check the register addresses in your firmware? They are probably in a .h file somewhere. If you can read and write most registers you are in the correct mode which is GEN4882 mode.
Also, what is the value of the constant PON in your firmware?
After the FindLstn can you read the BSR and DSR and report those values?
I prefer to keep our communication on the forum so others may benefit.
Message 10 of 151
(5,325 Views)
