tektronix tds 694c with USB-GPIB
Hello Labview community,
we have a Problem with the Tektronix TDS 694. We have download the Driver for this Hardware Tektronix tktds7xx an connected  the oscilloscope with PC over USB-GPIB, that works good an example program  can connect. Now we want to read Oscilloscope memory after the Trigger from that. An Labview example starts good and it´s come no failure in process, but no Data is showing or other functions working. The display shows a little flickering an that’s all. In the summary no data, no error but flickering 😄
thanks for answering
(3,582 Views)
hello, today i search for reason an i found NI Trace in Labview by the record for my execute my VI. In the Attachments you see what i record.
bye
(3,557 Views)
Hello vertigo,
whats your state, do you still need help in this topic?
If so, please describe your problem / method more detailed and add some screenshots of your VI and maybe a picture of the oscilloscope display.
Kind regards,
JoLe
Applications Engineering
www.ni.com/support
(3,487 Views)
