some errors from building lsb file in c .net
when i built a lsb in c++.net,using the same costom build command:lvsbutil $(TargetName) -d "$(WkspDir)\$(OutDir)".The error-error PRJ0019: A tool returned an error code: Performing registration-always appear although i had changed so many times the setting!
to NI,there are so many questions about the building lsb file in C++.net,why you don't give a explicit answer about it?!i think there must be sth wrong or different from the building in vc++6.0 except that the linker part.
you'd better show all the users some explicit steps, nothing is better than a graphic tutorial!
thx,hoping your response!
(3,098 Views)
I wanted to go ahead and link in your forum posting explaining how you were able to fix your problem.
Also, you may also find this KB useful:
href="http://digital.ni.com/public.nsf/websearch/393F5E45ECC9396A86256D02006
FE405?OpenDocument">Know...
Kileen C.
(3,098 Views)
