Serial Modbus Protocol driver
Hello there,
I'm trying to find MODBUS RTU driver (serial communication driver) for
Labview. I'd really appreciate that very much.
(5,502 Views)
Hi rolop,
National Instruments offers a number of MODBUS RTU drivers that are specific to the PLC device. LabVIEW essentially functions as an OPC client with other third-party OPC servers using DataSockets. National Instruments also has a product called Industrial Automation OPC Servers that provides an OPC Server for a large number of PLC communication protocols, including Modbus RTU. Industrial and Automation OPC Servers installs a program called Lookout Protocol Drivers (LPD).
In the Lookout Protocol Drivers , the co
mmunication settings can be configured for your PLC (the Modbus RTU, in your case). LPD then communicates with the PLC by running as the OPC Server and exposes all the registers of the PLC as OPC items. You can then write your LabVIEW application as an OPC client using DataSockets to read/write to the PLC. The following is a KnowledgeBase article detailing LabVIEW support for Modbus:
Do LabVIEW and LabVIEW Real-Time Support Modbus?
Hope this helps. Have a great day!
Kileen Cheng
(5,502 Views)
Hi rolop,
To find ModBus Driver (RTU or ASCII, serial or TCP...)for LabVIEW, try this URL http://www.saphir.fr/SAPHIRnet/Admin/home.htm
You can download a demo version to test driver with your hardware.
I hope that it help you...
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(5,502 Views)
I am not able to access the website for downloading the modbus driver. Where else can i find a modbus driver for labview to communicate with my modbus device?
Thanks in advance.
(5,502 Views)
The WebSite has changed recently 😞
the URL is now :
http://www.saphir.fr/FR/produits/pilotes/modbus/index.htm
unfortunately the site is only in french...for the moment I think. i believe that you can have more info at this e-mail : support-ModBusVIEW@saphir.fr
I hope that is not too late for the answer...
Olivier
Olivier Jourdan
(5,501 Views)
