‎03-26-2010 04:20 AM
‎03-26-2010 05:10 AM
RS-232 is intended for point-to-point communications -> unless your PC has 3 serial ports (which I doubt) you should choose a different BUS (such as GPIB or ethernet).
Regards
‎03-26-2010 05:24 AM
...or use a RS232 interface with several ports. For example from NI.
‎03-26-2010 07:41 AM
You could also use 9 pin rs232 to USB converters.
Curt
