send bitstream not string over gpib
I have an instrument, through which I actively communicate via gpib (usb-gpib-hs actually). I now need to send the instrument a series of 16bit integer values (0's and 7fffxh's alternating). I have tried flattening the array of int16's into a string to send but the string does not convert correctly. I have to also send the instrument the number of bits that will be sent as well as the 16bit checksum. It is the checksum that fails. I know the instrument is operational, so I can eliminate that.
How do I send the int16 bitstream via gpib without converting it to a string first? IF there is not a way how do I properly convert it? Thank you in advance
(3,636 Views)
Are you using LabVIEW? If so, how do you have the byte order set with the flatten to string? Little or big endian?
(3,625 Views)
and instead of flattening to string I would use split integer to et bytes and then put these in an array of bytes that can be converted into a string, not flattened
greetings from the Netherlands
(3,596 Views)
Dennis
You were right. I needed to send it little-endian rather than big-endian. That is instrument specific. Thank you!
(3,591 Views)
