rs232 cable
Hello!
I've been writing a program to communicate with TTi  1705 programmable multimeter and unfortunately, there is a catch: TTi says that I should use RS232 interface with XON/XOFF or NONE handshaking to communicate with PC or others controllers…
Communication settings
baud -9600
parity- none
handshaking- XON/XOFF /NONE
data bits-8
So, if I'm using regular RS232 cable it isn't working (with XON/XOF or NONE)-I just can send commands and there is no answer despite that DDM implement commands , if I'm using RS232 with only 3 physical  wires (TXD,RXD,GND )it's working well. Can I get your advice how to solve this issue?
(3,560 Views)
I don't understand exactly what you are saying. You say there is no answer but in the next sentence, you say it is working well.
XON/XOFF handshaking is a software method so a 3 wire cable (if wired correctly) will work. Verify what the instrument is set to and then set your code to match. I would also suggest using a terminal emulation program such as Hypertermina, Procomm, Putty, etc. to check basic communication before writing a program.
(3,532 Views)
Hi Dennis!
I mean that if I'm using RS232 cable made by me  with only 3 wires it's working well, with another standard cables it does't work. The same thing happens with Hyperterminal- with my cable it works well- I can communicate with device, with  another cables there is no responce.
In any case, thanks for the answer )))
(3,514 Views)
The other lines in your cable are DTR & RTS, those are only needed for hardware handshaking.
I think you have the hardware handshaking turned on in some way in the software.
OR
If you use a custom made cable it's possible TX/RX (pin 2/3) are straight (ping 2 -> pin2 ) and not crossed (pin2 -> 3 and 3 ->2, GND=5), that might be the reason it's not working.
(3,508 Views)
