read current temperature from watlow F4
How do I read the temperature form the watlow F4 using driver.  I have no success of finding the Modbus Register.
Balendran
(3,594 Views)
Hello Balendran:
Thank you for contacting National Instruments. Just to clarify things, are you looking for the driver or do you already have the driver. If you are looking for the driver it can be found here. If you already have the driver, then I was wondering what environment are you using to program?
Roland A.
Check out VI Roadshow
(3,567 Views)
Already got the driver.  We are trying to use it on a thermal chamber that we got from "Associated Environment System".
I just looked at the driver example, may be I found a way to read the temperature. But, I'll have to try it on.
Thank you,
(3,558 Views)
