02-20-2007 12:48 PM
02-20-2007 02:46 PM
Yes, these cards appear to be quite old. Quatech offers DAQDRIVE drivers for all their products, see this page
http://www.engberg.dk/Backq/software/lvd.htm
Hopefully you are still working with LabVIEW 4 under Windows 3.1![]()
Maybe they have updated drivers, I see Quatech was bought by Superlogics, probably best for you to contact them directly to see what support they have for LabVIEW.
http://www.quatech.com/products/daq.php
02-21-2007 02:25 AM
02-21-2007 03:30 AM
Max will not find them...
However, most external driver for LabVIEW work by calling some driver dlls, and in some cases the manufactor even provide a wrapper dll for better use in LV.
If you look into the LV 5 driver vis you might find dll calls (Needs LV5 or 6 ). To use them in LV8... you might need to rewrite these dll calls if the update from 5.0 -> 6 ->7 ->8 will not work or is not possible.
Look into the LV-Help 'Using external code in LabVIEW' (or so) found in the Docs or right here http://digital.ni.com/manuals.nsf/websearch/8D930295FFBF9F7686256D2C00624728
