Hello all,
I am using NI PCI 8433 card. I would like to programatically determine which Port is associated with which COMx. or which port is associated with which serial resource. We can check this using MAX. I would like to do this using labwindows/CVI so that I can open the session for that resource using NI VISA. Any kind of help is appreciated.
Thanks in advance.
Sri Vidya
Well, If you were using LabVIEW you could use the NI system configuration API. Hmmmm When will this API have LabWindows/CVI support?
So dont we have any api to get the mapping for the NI PCI 8433 ports to the corresponding resources in labwindows/cvi?
Hi!
I have quite the same problem. I want to know to which board are belonging my COM port. I have a PXI 8433 board, i use labview, and using visa functions i can retrieve lots of informations about the differents board present in my chassis i.e. the resource Name (ASRL6::INSTR), the Interface description (ASRL6 (COM6 - PXI-8433/4)) .... . The probleme is i can't determine to which board are attached the COM port. When i look in MAX, we can see that :
How can i know that programmatically ??
Thanks for your future answer ...
I don't have hardware available to test this but this snipette should get you headed in the right direction in getting max information from LabVIEW
Hi jeff, thanks for your answer!
I checked your code, i've done quite the same using visa properties. I also tryed with the system API, but it doesn't work.
With your code i get the error (-2147220623: NI System Configuration: (Hex 0x80040371) The property does not exist for this resource) when i call the property node ConnBusType with a serial interface. I think this property can't be access with COM port.
And that's all the problem, a lot of properties are not avaiable for serial port, you can see that from MAX, when you open a visa test panel. For example the attributes VI_ATTR_MODEL_NAME, VI_ATTR_SLOT, VI_ATTR_PXI_SLOTPATH... doesn't appear in the list... The only interesting propertie is VI_ATTR_INTF_INST_NAME i read : ASRL10 (COM10 - PXI-8433/4), so i know my COM port com from a 8344 board... but if i have more than one 8433 board, i can't make the link ...
So i'm still searching, but i think it's just not possible and i wonder how MAX can do that ...
Sounds like a problem. perhaps the system hardware API could use some additional functionallity. Good thing there's an Idea Exchange
