problem with the signal "activate" of GPIB-USB-B
What is wrong when the signal "activate" of GPIB-USB-B does not work? What can I do?
(2,993 Views)
What exactly do you mean? Activate is not one of the handshake lines or interface management lines of the GOIB bus. It's not a control sequence  or common command either. If this is an instrument specific command, please provide the make and model of the instrument you are trying to talk to.
(2,983 Views)
