ATR program
I want to communicate with a Climate Chambre over RS232 in Diadem, I programed a VBSccript to do this but it takes a bit to long to recieve the information. So I tried to proram a ATR file, which should be very simple but I ran into a problem:
I need to send this string to the Climate Chambre and it sends back the Temperature:     $01I <CR><LF>
my code looks like this:
init
  SET com1 TO=500 EOL=\013
end
input
  write com1 "$01I"
  read com1 "%AR"
end
as you can see my problem is with the <LF> I´ve tried "$01I\013\010" , EOL=\013\010 and many other strings with no success.
thank your for your help
john
(3,892 Views)
HiJohn,
did you try this:
EOL=\10
write com1 "$01I$0D"
or
write com1 "$01I$0D$0A"
Daniel
NIG
(3,880 Views)
Thanks for your help,
I found the the problem, the string I was trying to send  was "$01I" and the ascii character "$" is represented by \036 so,
I just sent:
EOL=\010
Write com1 "\03601I\010"
now it works 🙂
(3,866 Views)
Graet and good luck to you and your project!
(3,863 Views)
