problem with connection to the driver
the gpib primary address is not correct when i plug in the usb/gpib interface-Agilent 82357A.How to set the primary address?I m using labview 6.1. There is an error like get module status.vi keep pop out at error out dialog box when i run the program.HOw do i fix that?This error happen with all the VI supply by Agilent driver(Hp816x).I m using Agilent 8163A lightwave multimeter.Thanks for answer my question.
(3,400 Views)
I think this Knowledgebase will help you to get your resource names and primary addresses correct and allow you to use LabVIEW to interact with your instrument when using the Agilent GPIB board.
http://digital.ni.com/public.nsf/websearch/E56D3D4866BE0A8A86256942006626F0?OpenDocument
Hope this helps,
Steven B.
Applications Engineering
(3,400 Views)
