pda + vending machine
Hi
I am working on a EE project. MY project is a PDA controlled vending machine. The project has two parts. Firstly I have to make a LAbview pda software and then transfer it to the PDA.
The second part is the vending the machine. I need to konw what microcontroller should i use with which i can attach a bluetooth adapter and then use labview fpga to program the mcu to be able to move a 24 V motor. The MCU needs to be connected to a relay because one of the possible three motors should be working at one time corresponding to the motor that is required to vend the item.
can someone help me with the MCU , blueetooth adatper. also i would need to know what power supply i should use for the MCU and the motors. each motor requires 24 V.
thanks
Message 1 of 1
(4,424 Views)
