load.cpp error
i fail to run my VI and it shows load.cpp line:4081 failure. what happen?
(3,384 Views)
There are number of threads on this error. Here are some:
Failure : "load.cpp", line 4081
Failure : load.cpp in line 4081
failure at load.cpp in line 4081
Is
there a fix yet for error load.cpp line 4081?
They all happen when you try to open in LabVIEW 6.1 a VI, that has some tab controls on its front panel, and that was developed in the student or evaluation edition version 6i.
If you send me the VI that causes the error, I may be able to recover it. You can either post it here, or send it to support@ni.com
Zvezdana S.
(3,384 Views)
