12-20-2012 01:24 PM
Linux crashes when I click on a VISA resource constant (block diagram) or control (front panel). This happens on LabVIEW 2009 SP1 32-bit for Linux, running on CentOS 6.3 (similar to RedHat 6.3). I updated the VISA drivers to 5.1.2 and that didn't help. Thanks in advance for any ideas from the five Linux guys out there.
12-21-2012 06:59 PM
Hello Marvin,
How many GB of RAM does your computer have? If you have more than 4GB of RAM, then you can fix this by using 2 GB of RAM. This is a known issue and a Corrective Action Request (CAR#184364) was filed. I hope that this helps!
Jason D
Applications Engineer
01-09-2013 04:39 PM
Hello Jason, thanks very much for your reply. I purchased and installed a 2GB RAM stick for this purpose. Unfortunately LabVIEW still crashes when I edit a VISA control. Any other ideas? Is my bug different than the known bug? Is this fixed in LV 2012?
Marvin
01-10-2013 11:19 AM
Hello Marvin,
Could you tell me if the program crashes when you create the VISA resource object, or just when you are trying to select a device from the list? Do the shipping examples work? If you are connecting to an Agilent device, the Agilent I/O Libraries Suite was not compatible with the most recent versions of VISA until version 15.0, so updating that suite may be helpful. In terms of the CAR I mentioned, it sounds like the issue you are running into may be different than the one specified, due to the workaround not resolving the issue.
Jason D
01-14-2013 02:21 PM
Hello Jason,
My problem was resolved with LabVIEW 2012. To answer your question, LabVIEW would crash only when trying to select a device from the list. Thanks for your help.
Marvin
