keithley 181
I am looking for Labview drivers for an old (and still kicking) Keithley 181 ( and also 705 if possible).  I would very much prefer VISA driver but I don't have big hopes... GPIB will be OK too.... Thanks for any clues/help, etc
Regards
D
Message 1 of 8
(5,658 Views)
Here's all I found on NI's instrument driver network, both are GPIB:
The 181:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1579
The 705:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1094
And here is how you can search for drivers:
https://www.ni.com/en/support/downloads/instrument-drivers.html
Happy driving!
-AK2DM
Message 2 of 8
(5,655 Views)
hi,
The 181 link goes to a LabWindows driver.... (i am looking for Labview ones, VISA if possible; they are not on the NI website.... )
N
Message Edité par nitad54448 le 02-06-2008 08:37 PM
Message 3 of 8
(5,646 Views)
You can convert CVI drivers to LabVIEW with a wizard. What the wizard does is place a wrapper around a call library function node. The problem with the 181 driver is that it does not include a dll. You could post the driver to the CVI board and see if someone can create the dll for you. Your other options are to use the Instrument I/O Assistant or write your own driver. There is information at the Instrument Driver Network (under the Develop topic). LabVIEW 8.x has a wizard that will help you get started. Driver development is not all that difficult and a simple instrument such as a nanovoltmeter is a good one to start with.
Message 4 of 8
(5,640 Views)
Accepted by nitad54448
Here is the DLL.
Message 5 of 8
(5,630 Views)
thanks !
N
Message 6 of 8
(5,616 Views)
I'm new at this...
I'm using LV2014, perhaps that's why this DLL doesn't work.
Should I remove the LV 181 driver and just use this DLL instead?
Message 7 of 8
(3,646 Views)
What are you trying to do with the 181?  The instrument only has a small set of commands and you can see what they are and  how to use in this post:  https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Unable-to-communicate-with-equipment-using-G...
Message 8 of 8
(3,625 Views)
