install ni-visa scientific linux
hi,
i am not able to install ni-visa on SL6.
I get the following error:
Unpacking install files to /tmp/nivisa-5.3.0f0.install...
************************************ ERROR *************************************
* Kernel source does not appear to be installed for the 2.6.32-358.el6.i686 kernel.
*    Installation of the kernel-source package for kernel 2.6.32-358.el6.i686 is
*                   required to continue this installation.
Installer is aborted.
any suggestions?
thanx in advance
(3,823 Views)
I think that SL6 is not compatible with NI drivers.
Here you can check what Linux Distribution is supported by NI Drivers.
Try to look for the right Scientific Linux version. I think you need to downgrade to 5.6 at least.
Hope that this will help you.
Best regards.
Cla_CUP
NI ITALY
AE dept.
(3,802 Views)
Thanks for the attention Cla_cup, but probably this is not the solution.
In the page you linked (which I already checked), between 5 and 6 there is a comma, not a point. So I can use both SL5 and SL6, not SL5.6! 😞
(3,790 Views)
Oooohps...!! Smiley Sad
You're right. I'm sorry for previous wrong informations Smiley Sad. I'll check, looking for more detailed informations about the issue you posted.
If I'll find something useful, I'll forward it to you.
Regards.
Cla_CUP
(3,780 Views)
