06-18-2013 07:26 AM
hi,
i am not able to install ni-visa on SL6.
I get the following error:
Unpacking install files to /tmp/nivisa-5.3.0f0.install... ************************************ ERROR ************************************* * Kernel source does not appear to be installed for the 2.6.32-358.el6.i686 kernel. * Installation of the kernel-source package for kernel 2.6.32-358.el6.i686 is * required to continue this installation. ************************************ ERROR ************************************* Installer is aborted.
any suggestions?
thanx in advance
06-19-2013 05:42 AM
I think that SL6 is not compatible with NI drivers.
Here you can check what Linux Distribution is supported by NI Drivers.
Try to look for the right Scientific Linux version. I think you need to downgrade to 5.6 at least.
Hope that this will help you.
Best regards.
Cla_CUP
NI ITALY
AE dept.
06-19-2013 08:04 AM
Thanks for the attention Cla_cup, but probably this is not the solution.
In the page you linked (which I already checked), between 5 and 6 there is a comma, not a point. So I can use both SL5 and SL6, not SL5.6! 😞
06-19-2013 09:57 AM
Oooohps...!! ![]()
You're right. I'm sorry for previous wrong informations
. I'll check, looking for more detailed informations about the issue you posted.
If I'll find something useful, I'll forward it to you.
Regards.
Cla_CUP
