implementing HART protocol for smart transmitters
i'm writing a program for communicating with smart pressure transmitter using HART protocol. i started with labview 6i and was successful in writing to the transmitter. but when i tried to read from the transmitter using VISA read, i get a error message saying timeout expired before operation completed
plz do suggest some ideas to rectify this problem.
Message 1 of 10
(10,392 Views)
Hi
I have an old not so good implementation of the hart protocol that I thought I needed today but my customer was satisfied with the analog output on his controller. If you want I can sent it to you but it is based on the old serial library so you could have problems in newer labview versions
greetings from the Netherlands
Message 2 of 10
(10,381 Views)
thanx for ur reply
plz do send that program. i'll see if i could get help & info out of it. also do mention which labview version was used ?
Message 3 of 10
(10,364 Views)
I'm translating it to visa this weekend.
It will be in lv 7.1
Message 4 of 10
(10,360 Views)
thanx for ur help.
expecting the program this weekend. i'll try it and will giv u the result.
Message 5 of 10
(10,353 Views)
Hi Nisz
Here it is. Please test it because I really changed a lot.
I don't like HEX strings and translating from bytes to strings and back again, so I removed all crazy conversions.
I also have some pdf files but did not include or read them.
Message 6 of 10
(10,335 Views)
How can I find the device ID or the tag ID of the MFC without the software you mentionned?
Also do you know if there is a public available command set for the 0154 readout unit?
Thank you for your help.
Message 7 of 10
(10,083 Views)
    This will be very useful for me as well.  Thanks for spending the time to write all this.  It is unfortunate that Brooks makes this good digital mfc's however they make them so difficult to use.  In my experience digital products from other vendors are very easy to deal with and come with their drivers.
Two questions:
1)  You used the "Smart DDE" program to find the "Device ID"?
2) any advice on how to use your program if I am using multiple instruments daisy chained with the RS485 connection?
Nick
Message 8 of 10
(9,631 Views)
can you tell me if you had any success with using this Labview HART driver (brooks_visa.zip),
I'm also interested in using this driver.
Egon.
Message 9 of 10
(8,972 Views)
Hi Egon,
The answer to your question can be found here.
Rima
Rima H.
Web Product Manager
Message 10 of 10
(8,943 Views)
