ā10-27-2008 05:38 PM
| Trying to use the Hp 4280A 1MHz C meter/C-V plotter with
Labview drivers hp428xa and hp428xau and have the following error message:
error 1073807343 occured at VISA write in hp428A signal level and frequency.vi- hp428a continual measurement.vi filename.vi possible reason(s): VISA: (Hex 0XBFFF0011) Insufficient Location information or the device or resource is not present in the system. (continue) (stop) I would like to know what that means, am I missing something or is it just incorrectly connected, where can I find more information about using this device with LabVIEW? |
ā10-28-2008 03:57 AM
ā12-06-2012 04:13 PM
ā12-07-2012 03:41 PM
Hello Abdou_1,
Thanks for posting at NI forums! I think it is better if you open a new discussion. With the instrument driver installed, if you navigate to Help>>Find Examples in LabVIEW, you should be able to find examples for that device. Please take a look at those examples.
Best Regards,
Alina
