hp 4145B Instrument driver
Hi, I have downloaded the hp 4145B.dll and i can run each of these VIs separately to operate my device. But I want the data to be written in a text file or into an excel spreadshit. There is an output Vi file in the library however that does not write the data to any file. I am very new to labview so could anyone please tell me how to capture the X and Y data from the device and write into a text file?
(4,681 Views)
I believe you can use the File I/O -> Write to Spreadsheet File Vi. Just connect it to the X/Y data line and you should be good to go.
Hope this helps!
Best Regards,
Aaron K.
Application Engineer
(4,681 Views)
Hi Nabanita,
I am new to LabVIEW and 4145B.  I don't know where to download its driver you mentioned here.  Could you please give me more info?
(4,149 Views)
(4,145 Views)
