how to use subset string on read visa
Hi everybody,
please help me, i have problem about how to pick some string on String indicator (Display Hex)
please see pict below :
look at read buffer indicator, how to pick them one by one (Volt, Ampere, Watt, kVar, Cosphi) ? i wanna convert it to decimal. please help me
THANKS~
(4,448 Views)
Just use String Subset to pull out parts you need.  For voltage, you will want index to be 2 with a length of 4.  You can then do the conversion however you need to.
GCentral
(4,431 Views)
Or use the String to Byte Array function to get U8 values. Then you can merge and typecast.
(4,421 Views)
