how to create an application to receive the scpi ,like instrument firmware
hi ,
i need to write a windows application , this application would like a instrument firmware, when this application opened , the ni-visa could find a visa resource,like TCPIP::127.0.0.1::INSTR , if we use some tool to send SCPI command to this resource, this windows application can receive the command and do some work.
is there any document or sample code for reference?
(4,214 Views)
Are you planning to only be TCP/IP or do you also want Serial or GPIB?  If only TCP/IP, then you actually do not want to find a resource:  you want to be a listener and let whoever connect to you.  Look in the Example Finder (Help->Find Examples) and look for Simple TCP.lvproj (Networking->TCP & UDP) for some ideas.
GCentral
(4,159 Views)
thanks , i tried this project ,it can work!
(4,099 Views)
