08-13-2019 10:07 PM
hi ,
i need to write a windows application , this application would like a instrument firmware, when this application opened , the ni-visa could find a visa resource,like TCPIP::127.0.0.1::INSTR , if we use some tool to send SCPI command to this resource, this windows application can receive the command and do some work.
is there any document or sample code for reference?
08-14-2019 06:31 AM
Are you planning to only be TCP/IP or do you also want Serial or GPIB? If only TCP/IP, then you actually do not want to find a resource: you want to be a listener and let whoever connect to you. Look in the Example Finder (Help->Find Examples) and look for Simple TCP.lvproj (Networking->TCP & UDP) for some ideas.
08-15-2019 05:08 AM
08-18-2019 09:51 PM
thanks , i tried this project ,it can work!
