how to control scanner planar using labview
You can try what I suggested here.
Message 11 of 17
(2,228 Views)
thanx that has solved the problems.
Message 12 of 17
(2,206 Views)
i meant to design limit switch to control both left and right movement of polarization of motor, but this is connect through an LPT PORT i have ideas on how to start. could anyone help me out.
thanks
Message 13 of 17
(2,001 Views)
Accepted by awans
i'm having trouble to use labview read 5V from the parallel LPT PORT or even to detect 5v on write data. this is meanst to control limit switch on left and right directions
Message 14 of 17
(1,954 Views)
Please see the attached and check if there is anything Iam doing wrong
cheers.
Message 15 of 17
(1,946 Views)
hey could anyone help out to convert number to array in order to display on the graph.
Message 16 of 17
(1,860 Views)
You have marked this thread as solved. You have marked as the solution, a question of yours. I really don't understand that or what you are saying in your last post.
Message 17 of 17
(1,852 Views)
