how to chose channel
Hello to everyone.
I have the follow question.
I have a device (Lakeshore, Resistance Bridge) and I have signals from 3 sources and this signal are measured in 3 channel.
So, my question is how to choose a channel? (using labview)
p.s. I can communicate with my device using max, aglient suit
Thank you
Something is rotten in the state of Denmark
(3,311 Views)
If it's this model, then download the driver. If it's not, then yuo can use the VISA Read and Write functions to send the commands you've been using in MAX and read the results. If it is a different model, you still might want to download the driver to get and idea of how to write your code. You also have the option of using the Instrument I/O Assistant.
(3,307 Views)
Thank you Knight)))
everything is works
(3,278 Views)
