forced trigger TDS2002
I ám new to labview and i have the next problem. I want to test a device that produces 8 pulses of different value's.  I use a TDS2002 in the Normal triggermode. Can I sample when a trigger event occour ? and reset the scope for the next event ?
(3,393 Views)
 Hello Jos,
       I first recommend that you download and extract the LabVIEW Plug and Play driver for your instrument from IDNet into your inst.lib directory.  After doing that, you should take a look at the Edge Triggered Acquisition Example from the driver and see how it works on your instrument.  Then, I recommend that you see if you can the Read VI into a while loop.  I am not sure how far apart your different pulse sources are, but you might have to change some of the timeout values or implement some delays in your code.  Let us know how it goes.
Cheers,
NathanT
(3,391 Views)
Hello Nathan,
Thnx for your quick reply.
 Your information is very usefull. I'am going now build the application i let you know how i solved my problems.
Greetz Jos
(3,359 Views)
