‎03-09-2006 12:46 AM
‎03-22-2006 09:15 AM
‎03-22-2006 09:24 AM
‎03-22-2006 09:30 AM
The problem you experience is generated by the default setting of LabVIEW to use a localised decimal point.
If you switch that off in the options you have a normal system. Everybody in Europe is having problems with this one.
Our American friends simply were too friendly when they defaulted this option to use a localised decimal point
and afterwards invented a lot of software with %. to use a localised decimal point togetehr with a normal decimal point.
I have seen only one instrument that had the option to change the decimal point and we decided to never use that.
success, you are not alone in this struggle
I had already tried to force the format with "%." but it changed nothing. So I have changed the Regional Settings and it worked... Thank you very much for answering me.
Eric
‎03-22-2006 11:08 AM
