03-23-2005 01:36 PM
03-23-2005 02:55 PM
03-23-2005 03:21 PM
03-23-2005 03:33 PM
03-23-2005
03:53 PM
- last edited on
11-12-2025
08:10 AM
by
Content Cleaner
You already have the configure VI in your code, right before the read VI. The timeout input is on the top. Just hover above that input, right click and select Create>>Constant. Then, change the 10000 (10 seconds) to 60 or 70000.
Also, I suggest you move the configure VI out of the loop. It should only run when the code starts. In general, VIs which pass errors, which don't have their error output wired to something, pop up an error message. If you wire the error output of the read VI, the error message won't pop up.
Also, your VI is a bit messy, with wires not being straight. You should organize it more, for your sake. To learn more, I suggest you read the LabVIEW user manual. Also, try searching this site and google for LabVIEW tutorials. Here is one you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide.
03-24-2005 02:31 AM
