example visa and com and VB 6
I need to write a driver for an agilent signal generator.
Got everything working when setting up the reference to visa32.dll.
I can not seem to figure out which I need to use when creating the createobject function in VB.
This way I am more flexible for upcomming versions.
any hints?
cheers,
Jeffrey
(5,237 Views)
There are two VISA APIs, which can be used with VB6 --- VISA-C and VISA-COM.
Looks like you are using VISA-C API, interfacing with VISA32.DLL.  In this case you don't have to call CreateObject() function, because VISA32.DLL is not a COM DLL.  You can simply starts from viOpenDefaultRM() and viOpen() functions.
If you want to write your codes with VB6's object style, you can use VISA-COM intead of VISA-C. In this case, you must import VISA-COM 3.0 Type Library (GlobMgr.DLL) and your codes must call CreateObject("VISA.GlobalRM").  Everything starts from the Resource Manager object.
(5,209 Views)
Thx for the information.
regards,
Jeffrey
(5,205 Views)
Sorry to intervene into the middle. I am kind of new in this and your posting is so helpful. I was wondering where can I get references for these 2 libraries, I mean I need all list of functions with explanation of syntax. I searched for those, but looks like I haven't pick the right word for searching those. Any help will be highly appreciated.
(4,380 Views)
For the reference manual, NI-VISA provides VISA C API online help and pdf doc. Agilent IO Libraries and KI-VISA provide VISA COM API help.
Furthermore, VISA spec documents will be helpful for undestanding the library.
http://www.ivifoundation.org/specifications/default.aspx
(4,368 Views)
